Currently, we are creating a switch on the LabVIEW GUI. By turning the switch ON, we execute ConfigureChannelFromXML followed by StartBC, and by turning the switch OFF, we execute StopBC. We are verifying the operation of this VI. When we repeat turning this switch ON and OFF 110 to 120 times, the following error occurs in ConfigureChannelFromXML, and the process stops. Could you please provide the cause of the error and the countermeasures?
BTI1553LV.lvlib:Error Converter (ErrCode or Status).vi<ERR>
403001: Failed to create the 1553 bus controller message list (When calling BTIDriver API function BTI1553_BCCreateList, encountered internal error -31=ERR_BADMSG The specified command block is not a message block (BTICard))
