Please check the visaconf.ini file on your system and see what the value is for MaxNumResources. The default value for this property is 64 for LinuxRT systems. Please update the MaxNumResources value in visaconf.ini to a number higher than 64, such as 96 or 100, and see if it resolves the issue. The path for the visaconf.ini file is /etc/ni-visa/visaconf.ini.
