The Failed to Load or Create a Probe error when probing an OPC UA Reference in the LabVIEW Real Time environment is a bug. As a workaround to probe an OPC UA Reference, you can use a Custome Probe. For this:
- Right-click on the OPC UA Reference wire
- Select Custom Probe>>New and give any preferred name
- Save the VI
After this procedure when you click on wire to add a probe it will add the custom probe and the window will open without throwing any error message.
