TestStand Crashes When Opening Test Monitor Client Result Processing Options
Updated Oct 20, 2026
  • SystemLink 2025 Q1
  • TestStand 2024 Q4
  • SystemLink
  • SystemLink Client
  • SystemLink Server
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
  • SystemLink Enterprise
I recently installed SystemLink Client 2025 Q1 support for TestStand 2024 Q4. After the installation, I had to resave my custom model plugin sequence file (NI_TestMonitorClient.seq) to resolve updated types. Now, when I try to open the result processing dialog, I get an error message, and then TestStand crashes.
A non-execution thread running .NET code has thrown an unhandled exception. This can happen if your code causes an exception in a finalizer or if you create new .NET threads and an unhandled exception occurs in one of those threads. The .NET considers this a fatal error and will terminate the process once you dismiss this dialog. There is a risk that the process is now in a bad state so saving files might put them in a bad state as well or result in additional errors. The following are the details of the unhandled exception which was thrown:
System.Exception: The component 'NationalInstruments.Skyline.TestMonitorClient.OptionsDialo g' does not have a resource identified by the URI /NationalInstruments.TestMonitorClient2023; component/optionsdialog.xaml".
at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at  NationalInstruments.Skyline.TestMonitorClient.OptionsDialog.InitializeComponent()
at Nationalinstruments.Skyline.TestMonitorClient.OptionsDialog..ctor()
at Nationalinstruments. Skyline.TestMonitorClient.OptionsDialogLauncher.<>c.<ShowDialog>b__6_00
This is a known issue that will only happen if you save the NI_TestMonitorPlugin.seq for the first time after migrating it to TestStand 2024 Q4. You can avoid the issue by closing and restarting TestStand after saving the model plugin sequence file.
Note: NI recommends keeping all your work saved, otherwise you might lose data because of the crash. 
Saving the sequence file should be only necessary if you're modifying the NI_TestMonitorPlugin.seq, If you're not planning to modify it, please do not save the file.
