LabVIEW Class VIs Broken After Adding a New Element to the Private .ctl
Updated Feb 6, 2025
When adding a new element to the private control (.ctl) of my LabVIEW class, my class VIs break and I am getting the following errors:
VI Errors
ROOT CAUSE: Dependency is broken
Owning library has blocked execution of the VI.
Details
The VI is broken because it depends (possibly indirectly) upon a broken file. Fix the errors in the other file. Other errors listed here indicate how the other file is breaking this VI.
Broken dependency: Parent.lvclass:Parent.ctl
This LabVIEW issue occurs because the changes made to the private control are not applied. To solve the issue in the private control, select File>>Apply Changes.
