Currently, you can’t conditionally call a custom execute within a package during updates. To manage this, add logic to your custom execute code. Set a flag during the initial installation or update, such as a specific file. During subsequent updates, the custom execute can check for this flag to decide on actions. Ensure the flag is removed during uninstallation.
The section below describes a simple example script you could use to differentiate installs from updates in custom executions.
Using a file as a flag for updates
During Install or Update
In your custom execute batch script, create a file named install_flag.txt in a specific directory if it doesn’t already exist.
@echo off
if not exist C:\path\to\install_flag.txt (
REM You might want to add some custom text to the install_flag.txt file to indicate installation status or details.
echo Installation complete > C:\path\to\install_flag.txt
echo Performing custom action
REM Add your custom action code here
) else (
echo Skipping custom action during update
During Uninstall
Remove the install_flag.txt file.
@echo off
if exist C:\path\to\install_flag.txt (
del C:\path\to\install_flag.txt
By using this method, you can control custom executes during updates, ensuring they only run when necessary.
