I want to write data to an array in a sub-cluster located in a main cluster through refnums.
To do this, follow the steps below:
The steps above should allow you to manipulate the array in a sub-cluster.
This image is attached as a snipped. Download it and drag-and-drop it onto the block diagram to convert it to a LabVIEW code. If it did not help, try downloading the snipped from the attachments.
