LabVIEW Built-In Library Header Files in NI Linux Real-Time
Updated Mar 27, 2025
  • LabVIEW Real-Time Module
  • NI Linux RT System Image
  • Measurement Studio
  • LabWindows/CVI
I am using NI Linux RT and would like to use LabVIEW built-in library eg. lvanlys.so in my C project. However I am not able to locate the header file for integration in my C project. Is there any reference to use header file on this LabVIEW built-in library?
lvanlys or most LabVIEW built-in library is designed to be called from LabVIEW. It assumes things like memory being passed as LabVIEW handles allocated with the LabVIEW memory manager. It would not be appropriate to be called from other languages.
NI do have LabWindows/CVI Real Time Module is for old Real-Time system, in other words, Pharlap environment. However, for Linux Real-Time system, it is not supported.
Measurement Studio is the NI solution for analysis APIs in C/C++.  However, because Visual Studio where Measurement Studio works is for Windows application only, this cannot be used for Real-Time application development.
To conclude, you should use LabVIEW or use other third-party analysis functionality or library for development.
