- When running my LabVIEW code, I am getting an Error 1 coming from my TCP Close function, why is this happening?
Error 1 occurred at TCP Close Connection in VI
Possible reason(s):
LabVIEW: (Hex 0x1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Command requires GPIB Controller to be Controller-In-Charge
