Does the Digital Audio Toolkit Support 16-Channel TDM?
Updated Mar 28, 2025
  • Digital Audio Acquisition and Generation Toolkit
Does the Digital Audio Acquisition and Generation Toolkit support 16-channel TDM? The user manual only mentions 4, 6, and 8-channel TDM.
Yes, this toolkit supports a maximum of 16 channels per frame (TDM 16). To configure the system for 16-channel TDM, you can adjust the Channel Count per Frame. This parameter represents the number of channels that will receive data during a single frame cycle. Essentially, it indicates the total number of frames that will be transmitted across all channels within a given frame period.
The picture below shows the Channel Count Per Frame settings:
