NI Device Drivers Installation Stuck at LabVIEW Run-Time Engine 7.1.1
Updated Mar 26, 2025
  • NI Device Drivers
When I install the NI Device Drivers (August 2009), the installation consistently gets stuck at the NI LabVIEW Run-Time Engine 7.1.1. Despite multiple reinstallation attempts, the problem persists.
Currently installing NI LabVIEW Run-Time Engine 7.1.1 Part XX of XX
This may be a specific issue that only affects certain users or PCs, as not all users will experience this problem. To resolve this issue, you can try installing the LabVIEW Run-Time Engine 7.1.1 separately before installing the NI Device Drivers. The installer for the LabVIEW Run-Time Engine 7.1.1 can be found in the NI Device Driver August 2009 folder: DCD-Aug09-1\DCD-Aug09-2\Products\LabVIEW_Runtime_Engine_71\LV711RTE.
