Can You Use an NHR 9300 in a Facility Powered by a Diesel Generator?
Updated Jan 24, 2025
System
  • NHR-9300
Our facility is powered by a diesel generator, is it safe to use the NHR 9300 in this environment?
Most diesel generators do not allow for a reverse power flow (delivering power back to the facility) and could damage a diesel generator if done.
Since the NHR 9300 converts discharge (or load) power into clean AC power suitable for use within the facility, we only recommend using an NHR 9300 in charge mode when the facility power is generated by a diesel generator.  Discharge and Battery operating modes will cause power from the NHR 9300 to be sent back to the facility power.
