C function for ni<driver> Get Session Reference.vi
Updated Jan 21, 2025
Programming Language
  • C
Other
  • C Programming
  • In LabVIEW, there is a function known as niFgen Get Session Reference.vi. I would like to call the same function through C programming, however I did not find any. What is the replacement for this function?
  • I would like to use NI TClk in C programming with one of the NI modular instrument. In LabVIEW, there is ni<driver> Get Session Reference.vi to extract a session that can be used by the NI TClk function. How do I apply the same concept in C programming?
In C programming, there is no function for ni<driver> Get Session Reference.vi. For driver APIs that use ViSession for their session handles (e.g., niFgen, niScope, niRFGS, and niDMM), you can pass that directly to NI-TClk in C programming.
Take the niFgen C function as an example: niFgen_init, niFgen_InitWithOptions, and niFgen_InitializeWithChannels will output a ViSession type, which can later be used in NI TClk C function that require a ViSession type as input.
In LabVIEW, the ni<driver> Get Session Reference.vi is necessary to cast the wire type from an instrument handle to session reference so that the session reference can be passed into NI-TClk sessions.
