Potential Noise Transferring Through MGT Lanes in PXIe-6593
Updated Jan 22, 2025
  • PXIe-6593
  • PXIe-6594
I am planning on using the Digital I/O pins of the DIO port in my PXIe-6593. However, I am also planning on connecting the Multi-Gigabit Transceiver (MGT) lanes of the QSFP+ ports of this card to my Device Under Test. I am concerned that if I use the MGTs of the QSFP+ ports, I might introduce noise into the MGTs of the DIO port, and affect the connection to the other I/O pins of the DIO port. Can this happen?
The PXIe‑6593 is designed for engineers who need to validate, interface through, and test serial protocols. It includes a Xilinx Kintex Ultrascale FPGA to implement various high-speed serial protocols, and it is programmable in LabVIEW FPGA for maximum application-specific customization and reuse. The PXIe‑6593 takes advantage of FPGA MGTs for up to eight TX and RX lanes within the main QSFP+ ports, and up to four TX and RX lanes in the DIO port.
These MGT lanes are completely separate from each other, meaning that the MGT lanes in the QSFP+ port 0 are different form the ones in the QSFP+ port 1 and are also different from the ones in the DIO port. Therefore, there won't be any crosstalk between the different ports.
Given the hardware architecture used in the PXIe-6593 and PXIe-6594, the same applies to the latter.
