How to Exclude Subsequence Result from TestStand Report?
Updated Jan 8, 2025
  • TestStand
The user always utilizes subsequences in TestStand to better organize and manage their test program. However, not all subsequence results need to be included in the TestStand report. This article will guide you on how to exclude specific subsequence results from the TestStand report.
  1. Determine which subsequence's result needs to be excluded from the TestStand report.
  2. Select the relevant sequence call step that is calling the subsequence.
  3. Go to the Step Setting of the sequence call step.
  4. Go to Properties>>Run Options.
  5. Select Disabled for Result Recording Option
