NI-DAQmx 19.6 Can't Be Installed Into the PharLap RT
Updated May 30, 2025
  • PXI Controller
  • Phar Lap
Previously, I have NI-DAQmx 18.6 installed on my host PC(WIN7) and PharLap RT PXI. I want to upgrade to NI-DAQmx 19.6. After I install the NI-DAQmx 19.6 on the host, I can't find it when I try to install it to the PharLap RT in NI MAX. What should I do to solve this issue?
This issue can be resolved by the following steps:
  1. Delete NI-DAQmx 19.6 on the host.
  2. Install ni-cvi-2019-rt-module-x86_19.0.0.
  3. reinstall NI-DAQmx 19.6.
Then, you should be able to install NI-DAQmx 19.6 in NI MAX.
Note: If you can't find the installer of ni-cvi-2019-rt-module-x86_19.0.0, please reach out to NI technical support for help.
