What does 'maximum operating power' means in the X410 specification?
Updated Jan 8, 2025
  • Ettus USRP X410
Background:
I'm reading the X410 specification, and I found one particular value under RF -> Receiver -> Maximum input power, damage level which is not easy to understand:
the first and second row are understandable as they mean
<= 3 GHz, the input power should be less than +14 dBm
\>3GHz, the input power should be less than + 17 dBm; + 20 dBm for up to 5 minutes
but I'm not sure about what the third row means here.
Question:
What's the 0 dBm Maximum operating power means?
The first two are the damage levels - so nothing breaks if you accidentally input a power below that level.
The "Maximum operating power" is the input power you can actually use without saturation within the device. So for any frequency, we will have a gain setting that allows a 0 dBm input tone to reach the ADC without clipping. There are frequencies that allow a higher input power at the lowest gain values, but that's something we don't specify.
