I have a code in LabVIEW that utilizes a Modbus I/O Server to establish communication with an external device. The project has worked fine for several months, but suddenly, it stopped to function properly, and I started to receive error -1967353911. If I use a third-party software to test the communication with my device everything works, so I know that the configuration I set for my I/O Server in LabVIEW is correct since it is the same I have selected for the third-party software. I am not sure why LabVIEW is failing to communicate. The error message is presented below:
Error -1967353911 occurred at an unverified location
Possible reason(s):
LabVIEW DSC: The Modbus I/O server failed to send a frame. Ensure that the configuration of the specified serial port for modbus master is correct.
