How to Resize the Increment and Decrement Buttons in LabVIEW?
Updated Jan 14, 2025
This article explains how to resize the increment and decrement buttons for a numeric control on the front panel. Before resizing the buttons, you might need to change the height of the numeric control.
  1. Right-click on the numeric control and choose Advanced >> Customize...
  2. In the customization window, select Change to Customize Mode.
  3. Resize the buttons manually.
  4. Go to File>>Apply Changes to update the numeric control on your front panel.
  5. (Optional) If you want to save this as a template, choose File>>Save.
