When trying to use the LabVIEW Sound & Vibration Toolkit with LabVIEW 2024Q3, I encounter some VIs (for example, Orbit and Timebase Plot) that report a broken dependency error when placed on the Block Diagram:
ROOT CAUSE: Dependency is broken
Poly VI 'SoundVib_MCMDisplay.lvlib:SVX Orbit and Timebase Plot.vi': Plymorphic subVI is broken
This VI is broken because it depends (possibly indirectly) upon a broken file. Fix the errors in the other file. Other errors listed here indicate how the other file is breaking this VI.
Broken dependency: SoundVib_Resampling.lvlib:OAT Single Stage Interpolation with IC.vi
This error is shown in the following dialog box:
