You can adjust the height of a numeric control or indicator using a property node. To do this, right-click on the control or indicator, then select Create>>Property Node>>Numeric Text>>Size>>Height. Once the property node is created, you can modify the height by writing a value into it. If the property node is set to read, right-click on it and select Change to Write.
