I am using PCIe-6738 and trying to generate an analog output voltage by creating a task in NI MAX. But an error is shown as below. The same error happens when I am using a simulated NI-DAQmx device.
MISSING INPUTS:
One or more of the inputs to this step are not selected. Insert a step before this step which has an output that matches the type of signal this step requires.
