Error -2147467259 Occurs Randomly While Accessing Microsoft Access from Multiple PCs in LabVIEW
Updated Dec 31, 2024
  • LabVIEW Database Connectivity Toolkit
Other
  • Microsoft Access
I am using multiple local PCs to access a a local database file (.mdb) created using Microsoft Access. However, I encounter error -2147467259 randomly and unpredictably.
Microsoft does not support placing Jet .mdb files under high user load. Microsoft strongly recommends that you use Microsoft SQL Server or Microsoft Data Engine (MSDE) instead of Access when high user loads (that is, more than 15 instances) are required or anticipated, especially when updating is required.
To run an .mdb file by multiple instances, Jet makes use of a lock delay and retry interval. However, under high load conditions, you may exceed these intervals.
