How to Generate Clock Signal Using PXIe-6570 in LabView Code?
Updated Dec 19, 2024
  • PXIe-6570
  • NI-Digital Pattern Driver
Programming Language
  • LabVIEW G
I'd like to know how to generate clock signal using PXIe-6570 in LabView Code.
I know how to generate it in Digital Pattern Editor Pin View pane. And I see clock API in driver NI-Digital.
But how do I program the same clock output in LabView code?
  1. Refere to Clock Generator API.
  2. Program in LabView as below.
  1. Change frequency and channel as requirement.
Test result is as below.
