Reset Your DC Power Supply Message During PXI-41XX Calibration
Updated Jan 28, 2025
  • PXI-4130
  • PXI-4110
  • Calibration Executive
  • Calibration Executive 2023 Q4
When performing the PXI-41XX's calibration procedure on Calibration Executive with an unsupported power supply unit in manual mode, I get the following notice at any point after the Verify Current Measurement Accuracy step:
Reset your DC Power Supply
If I hit continue a few times, I get the error described in this article- Error -1074118647 When Performing PXI-4110 Calibration in Calibration Executive. However, the steps in the article don't help me
How do I get past this dialog box, and what does it mean to reset the DC power supply?
The message prompts the user to turn all power supply values to 0 or to disconnect the PSU from AUX lines on the PXI-41XX. After doing so, click continue.
The Calibration Executive will then ask you to reconnect the power cables, or turn on the supply again and set the power supply unit to the required values to continue with the calibration.
