To synchronize the XNET and Scope hardware, with LabVIEW or another development environment with access to the NI-SCOPE and NI-XNET drivers, you can use string-based routing.
This means you do not need export the signal from the CAN device to PXI_0 and allows the routing subsystem to automatically create the full route for you.
The recommended approach for configuring the trigger source is to use the event terminal of the NI-XNET device.
If you are using the function niScope_ConfigureTriggerEdge, pass the terminal name of the XNET device as the trigger source for the digitizer.
For example, The triggerSource argument in the function should be the string terminal of the XNET device, such as "\PXI1Slot2\TimestampTrigger".
The niScope_ConfigureTriggerEdge has the following signature:
ViStatus _VI_FUNC niScope_ConfigureTriggerEdge(
ViSession vi,
ViConstString triggerSource,
ViReal64 level,
ViInt32 slope,
ViInt32 triggerCoupling,
ViReal64 holdoff,
ViReal64 delay);
So for example, this would be
niScope_ConfigureTriggerEdge(vi, "\\PXI1Slot2\\TimestampTrigger", 1.0, 1, 1, 0.0, 0.0);
Verify that the event terminal you’re using is valid for your CAN application. If unsure, consult your XNET documentation for correct terminal names.
