Using FTP Access for Linux cRIO Target
Updated Dec 6, 2024
  • cRIO-9057
  • cRIO-9053
  • LabVIEW Real-Time Module
I want to access cRIO via FTP to check the deployed software. What settings are required?
To access cRIO via FTP, you need to perform a custom installation of the legacy FTP server. To install the FTP server, you must have software versions prior to 2020 installed on your host PC.
For data transfer to cRIO, it is recommended to use WebDAV or SFTP instead of FTP. For more information on how to use these tools, please refer to the document.
