GPIB-USB-HS+ Cannot Recognize on macOS 12
Updated Dec 20, 2024
  • GPIB Cable
  • GPIB Connector
  • GPIB-USB
  • NI-VISA
  • NI-488.2
  • Mac OS X
I have installed the NI-488.2 and NI-VISA drivers, but the NI-VISA Configuration cannot recognize the GPIB-USB-HS. It displays as USB0::xxxxxx::xxxxxx::xxxxxxxx::x::RAW. When I manually add static resources, there is no GPIB Device option available.
The NI-488.2 Software is not correctly installed on your system. Please follow these steps:
1. Restart your system.
2. Reinstall the NI-488.2 Software
3. Run the Troubleshooting Wizard again.
The error message displayed is as follows:
Error Message
No "GPIB Device" option in "Add Static Resource":
  • The latest version of NI-488.2 is 21.5, which is only compatible with NI-VISA 21.0. Although NI-488.2 supports macOS 12, NI-VISA 21.0 only supports macOS 11.x. Therefore, using NI-488.2 and NI-VISA together is not supported on macOS 12.x.
  • It is recommended to use NI-488.2 version 21.5 and NI-VISA version 21.0 on macOS 11 with an Intel-based processor. Note that these versions are not supported on Apple Silicon processors, such as the M1.
Starting from the NI-VISA 2022 Q4 version, macOS 12.3 is supported. However, this version no longer supports GPIB and PCI/PXI passports.
