NHR devices require SCPI over TCP communication, when the resource is added to a host PC using NI-MAX, the default option creates a VXI-11 session. To address this issue, create a Raw Socket following these steps:
- Open NI-MAX and go to Devices and Interfaces >> Network Device >> Add Network Device >> VISA TCP/IP Resource:
- Enter the IP address of the NHR instrument and set the port number to 5025:
Below is an example of a properly configured device in NI-MAX:
If the issue persists, contact NI Technical Support to continue the troubleshooting.
