1.Identify the camera files that you are using in NI MAX. In the below example it was Basler raL2048-80km.
2.Go to NI-IMAQ camera files directory at C:\Users\Public\Documents\National Instruments\NI-IMAQ\Data. Then delete or move the identified camera files from that directory.
3.Open NI Package Manager click the setting icon and place check mark on Show full version numbers and hidden packages.
4.Search for camera keyword and find NI-IMAQ Camera Files. Place check mark and press REPAIR.
5.After repair process completed, open NI MAX again, go to Tools >> Reset Configuration Data. Note that this process will reset the NI MAX database.
