This error message means that the path can't be resolved, so you should check your environment and confirm that the expected 'path' exists.
When using Remote Desktop Connection on Windows: there is a group policy that can cause Windows to create/use different temporary folders for each session, which may cause you to reference an "unexpected path", the usual tell is a number added into the path like: \2\. If you see this behavior, please try changing the group policy configuration. This external link showcases where you can find this policy.
