Error 200077 When Change Data Transfer Mechanism of USB DAQ
Updated Nov 7, 2024
I have a NI USB DAQ device that using DAQmx driver, and I wanted to use Interrupts or DMA as my data transfer mechanism by changing it using DAQmx Property Channel.
However, when I run a simple code using my NI USB DAQ device and use Interrupts or DMA as my data transfer mechanism, I am getting Error -200077 occurred at Property Node DAQmx Channel (arg 1) as below picture. How can I resolve this issue?
The implementation for Interrupts and DMA for NI USB DAQ is not possible since it is not supported. The possible values are only USB Bulk and Programmed I/O for USB-based on DAQmx devices.
NI recommend using PCI/PXI based MIO DAQ device to take advantages of the DMA or Interrupts data transfer mechanism.
