Astronics Ballard Module Doesn’t Detect in NI MAX
Updated Nov 7, 2024
  • Ballard MIL STD-1553
  • Astronics Ballard Avionics Driver
I have Astronics Ballard modules that have been slotted into NI PXI chassis but I couldn't see it in Device and Interfaces from NI MAX.
For your information, to check the Astronics Ballard module's connectivity you may use BTITST32.EXE/ BTITST64.EXE because the NI MAX Device and Interface will not show Astronics Ballard modules. To have guidance for installing the BTITST32.EXE/ BTITST64.EXE you can refer to Omnibus II (LV-222-xxx-xxx) NI PXIe User Manual.
