Timing Violation When Compiling FPGA in cRIO-905x When Certain Modules in Slot 5
Updated Oct 20, 2026
  • cRIO-9057
  • NI-9224
  • NI-9212
I am using cRIO-9057 fully slotted as below configuration.
I am facing timing violation error when compiling the FPGA bitfile even with a very simple FPGA code.
What is causing the timing violation error and how to solve it? Looking at the details, it was non diagram error and the code is simple enough that I can't find a way to optimize the code further. The same configuration and code works with cRIO-904x series.
There is a known issue when compiling certain modules in cRIO-905x in slot 5. At the moment, we have identified NI 9224, NI 9212, NI 9205, and NI 9203. It is possible that all NI 920x could be impacted. As a workaround, do not use these NI C-Series modules in slot 5.
