It is a known issue of XNET driver. The parameters are not saved on capture start. If you are using NI-XNET 2024 Q3 and prior versions, you have to fill the parameters every time before you start the capture. The issue has been fixed in XNET 2025 Q1 release officially. Upgrading to XNET 2025 Q1 and later versions will resolve this issue.
