Modifying LabVIEW Boolean Control Output Values
Updated Oct 31, 2024
Is it possible to modify the Boolean control to output values other than 0 and 1?
It is not possible to configure the Boolean control properties to output values other than 0 and 1 (e.g., 0 and values bigger than 1). This is because the Boolean algebra is limited to 0s and 1s.
However, you can program the code to achieve different output values. Below is an example of how you can modify the output values of the Boolean control through coding:
The code above will output 3 when the Boolean control is TRUE and 0 when it is FALSE.
