AI Range Setting for OP8935-F
Updated Jun 18, 2026
  • OP-8935
How to set the AI Range (10V or 30V) for the OP8935-F?
To set the AI Range for the OP8935-F card, you need to flash the new firmware and then reset the SLSC chassis for 5 seconds or longer. If the issue persists, the card may need to be returned for RMA to flash the new firmware.
