I have attached a connector called RTI-12308 to the rear side of SLSC-12202. There is a 6-pin external power connector here. I couldn’t confirm where this 6-pin connects to on the rear of the SLSC-12202.
The connection between SLSC-12202 and RTI 12308 is as below.
RTI-12308 was specifically created to handle the higher voltages of the SLSC-12202, and the 6-pin XP4 connector was used to prevent the RTI being used with lower-voltage cards.
