To configure the X-axis in the View Panel, you may need to use the Band Zoom function in DIAdem. To have a better understanding, you can refer to the steps:
- Click on Band Zoom at the top left of the Diadem Toolbar:
- After clicking on Band Zoom, your cursor will change to the Band Zoom symbol:
- From the curve, click on the minimum of the X-axis value that you need the curve to begin.
- Lastly, from the same curve, click on the maximum X-axis value that you want the curve to end at.
Then you will get a curve that is configured with the beginning value and ending value.
