Maximum Frequency of External Clock for DI13 of PXIe-6569
Updated Oct 11, 2024
  • PXIe-6569
In the sample project for PXIe-6569 (Getting Started FlexRIO Integrated IO.vi), there is an option to use external clock inputted from DI13. What is the maximum frequency?
The SerDes CLIP can handle up to a 625 MHz external clock. The basic CLIP supports up to 150 MHz. To use external clock from DI13, you need to select appropriate clock.
The clock is divided by 4 though, so the LabVIEW diagram will see a 120 MHz clock if you input 480 MHz clock. This is done to match the clock speed with the serialization/deserialization ratio.
