This is known issue started in LabVIEW 2023 Q3 and fixed in
LabVIEW 2024 Q3.
Configure SSL (WebDAV),
Asynchronous Configure SSL (WebDAV),
ConfigSSL (HTTP Client), and
Config TLS (SMTP) functions fail to use certificate files. Instead, you need to feed the certificates into the Windows certificate store and specify their paths in the way curl expects. The path to a certificate in the windows certificate store is
<store location>\<store name>\<thumbprint>. A practical example is
"CurrentUser\MY\934a7ac6f8a5d579285a74fa61e19f23ddfe8d7a". Thumbprint is usually a SHA-1 hex string which you can see in certificate details. Refer to
cURL documentation for further details.
Another option is to downgrade to LabVIEW 2023 Q1 or upgrade to LabVIEW 2024 Q3.
