Linux Real Time (RT) Freeze When Using an Application With Embedded UI
Updated Sep 11, 2026
  • NI Linux RT System Image
My Linux RT controller freezes when I am using an application with enabled Embedded UI.
This is a known issue that appeared starting from 5.15 and later NILRT kernels which is fixed in the 2024Q4 release. For now, there are three possible workarounds:
  1. Upgrade the target's software and drivers versions to 2024Q4.
  2. Modify the "rtgroups" file on the target on the current software and driver version:
  3. Downgrade the software and driver version to 2020.
    Note: This version is not currently supported and should only be used as a temporary workaround.
If the chassis crashes after these modifications, please contact NI Technical Support for further assistance.
