Change the Table Title in DIAdem Report by Using Script
Updated Sep 30, 2024
  • DIAdem
This example illustrates the process of modifying a table's title within a DIAdem report by utilizing a Python script. The script enables users to customize the report's appearance programmatically, enhancing clarity and presentation.
  1. You can use this property to change the table title in a DIAdem report through scripting. Examples in both VBScript and Python are available for reference.
  1. Create a new Python script in DIAdem.
  1. Copy the provided Python example code into the new script.
  2. Modified the example as highlighted below, this will update the title for Column 1 and Column 2.
Result
