Is It Possible to Mix Fiber Optic and Copper Cables for MXI-Express Gen 3 Modules?
Updated Nov 15, 2024
  • PCIe-8398
  • PXIe-8398
  • PXIe-8399
  • PXIe-8394
I would like to connect multiple pxi chassis to one PCIe-8398 but use a copper cable for one system connection and a optical fiber connection to the other system.
Yes, it is possible to connect different types of cables to the same PCIe-839x and PXIe-839x module. The boards read each cable individually and configure the port for that cable type.
There are a few restrictions that you need to consider when using Fiber Optic cables with MXI-Express Gen 3 controllers:
  • You can only connect a maximum of two Fiber Optic cables to each controller. The article attached in the Related Links section expands on this topic.
  • The MXI controllers will only support a x4 link with the Fiber Optic cables. You can't stack cables to increase the link.
