How to interpret a Maintenance Software report of ECUTS
Updated Sep 25, 2024
  • ECU Test System Maintenance Software
System
  • ECUTS-16001
  • ECUTS-16000
There are many contents in Maintenance Software report of ECUTS(ECU Test System). This article will guide you how to interpret a maintenance software report.
The report contains the following information:
  • Overall Status
  • General Information
  • System Configuration Verification Summary
  • System Components – General Information
  • System Ports – General Information
  • System Components – Operations Performed
  • System Components – Calibration Information and Current Temperatures
1. Overall Status
  • Displays a summary of the system's status.
2. General Information
  • Displays the report information:
    • Start date and time
    • End date and time
  • Displays the test system's general information:
    • Configuration Name
    • Model Name
    • Part Number
    • Serial Number
    • System Tag
3. System Configuration Verification Summary
  • Displays the results of the system configuration check step and enlists the components that were:
    • Name Changes
    • Missing Components
    • Components with Problems
    • Components Not Expected but Found
    • Missing Ports
    • Ports with Problems
    • Ports Not Expected but Found
4. System Components – General Information
  • Displays a table that enlists the instruments that are present in the test system with:
    • Name
    • Model Name
    • Serial Number
    • Firmware Version
    • Location
5. System Ports – General Information
  • Displays a table that enlists the ports that are present in the test system with:
    • Name
    • Type
    • Location
6. System Components – Operations Performed
  • Displays a table that details the actions that were executed on each component and their status:
    • Passed—The test for this component passed.
    • Failed— The test for this component failed. Refer to the report footnote for additional details.
    • N/A—The operation is not supported for this component.
7. System Components – Calibration Information and Current Temperature(s)
  • Displays a table that details:
    • Name
    • External Calibration Date
    • External Calibration Temperatures
    • Recommended External Calibration Interval
    • Self Calibration Date and Time
    • Self Calibration Temperatures
    • Current Temperatures
Above are introductions of the Maintenance Software report of ECUTS
