NI doesn't offer a cDAQ chassis that operates independently, however, the
CompactRIO platform might be a better alternative for this application: You can develop a code and load it into the cRIO to act as a stand-alone solution, be aware that this platform is more expensive and will require more advanced programming knowledge.
