Deploying an Application that Use NI RFmx Analog Modulation
Updated Sep 3, 2024
  • RFmx Analog Modulation
  • RFmx Digital Modulation
I have an application that uses NI RFmx Analog Modulation, a part of NI RFmx Demod. Do I need a separate license to deploy this application in the runtime environment?
Since NI RFmx 20.7, NI RFmx Demod is available as NI RFmx Digital Modulation and NI RFmx Analog Modulation and requires a separate license for analog and digital modulation use cases. To deploy an application using these software, a separate deployment license is required.
For NI RFmx Analog Modulation, you need NI RFmx Analog Modulation Deployment License.
The part number for NI RFmx Analog Modulation Deployment License is 788020-35.
