The installation of InstrumentStudio starting from the 2024 Q3 version now include the
Professional Edition. This version requires a license, but you will still be able to access the
Lite Edition, which is free.
The differences between the
Professional and the
Lite Editions are listed in
Select Your NI InstrumentStudio Edition - NI.
In order to avoid the Activation Dialog Wizard, you can click
Continue on the
Let's Get Started window:
If you clicked on
Start Trial, you can finish the trial period using the Professional Edition features, and you will still be able to use the
Lite Edition features after that period.
If you have a Serial Number for the InstrumentStudio Professional software, you may click on
Activate and proceed with the activation.
