Error -1074116003 when Running Random Interleaved Sampling with NI-SCOPE
Updated Dec 31, 2024
  • NI-SCOPE
I am using immediate trigger with the niScope Random Interleaved Sampling.vi and when I run the program I get the following error.
Above error occurred because immediate trigger is not supported on Random Interleaved Sampling (RIS) program. The requirement for RIS mode is the trigger event must be identical for every sweep, so you need to use analog edge reference trigger.
