Error -1074118498 when Enabling Time Interleaved Sampling in NI-SCOPE
Updated Dec 31, 2024
  • NI-SCOPE
I am using niScope Configured Acquisition.vi from NI-SCOPE sample program and I want to run the program with time interleaved sampling mode, but I am getting below even though I have set the Enable TIS property to TRUE.
In order to use niScope Configured Acquisition.vi with time interleaved sampling mode, you need to add Active Channel Property and Vertical:Channel Enabled PropertyActive Channel Property is used because you want to specifically specify which channel will run the time interleaved sampling mode. Also, the Vertical:Channel Enabled Property must be set to TRUE because the specify channel will acquire waveform as niScope Configured Acquisition.vi is a waveform acquisition programming.
